Quick question before I tear out the remainder of my hair. I have everything removed and the pump flopping around, but it just will not go back far enough to clear the pulley shaft so I can get it out. I have removed the 2 bolts at the rear bracket so the bracket is still attached to the pump, but I just cant get in to unbolt the bracket from the rear of the pump. It looks to me that it'd be possible with the starter removed.
So do I just need to persevere with the bracket or should I just take the starter out? I really cant tell if it will clear even with the bracket off!
DM
DM
