Well finally got round to removing the transmission ( lovely job ) first problem the torque convertor front spigot had sheared off in the crank ... looks like it had been like this for some time ..... lots of drilling spitting blood but finally got it out.
Right the easy bit swap mounts etc to replacement box (same serial numbers on box) fit torque convertor that was supplied with box from 93 surf and the damn thing will not engage no matter what I do, so i try the old tc and it mates up straight away 3 clunks and in position ? The splines are the same but like i said no matter what i do the replacement tc will not engage. I have read that some tc fitting requires the gearbox to be stood up vertical and this helps engagement which is great if the gearbox didnt weigh a ton!!!!
Any advice appreciated
