does the idle up switch just chenge revs or is it like a choke and does it alter the fuel air mixture when activated.
idle up
AFAIK it just raises the revs, making no other changes.Originally posted by thumperdoes the idle up switch just chenge revs or is it like a choke and does it alter the fuel air mixture when activated.Maurice
Should't be a problem as I think it also disengages when you select drive.Originally posted by thumperthat'll be handy as i use mine in the morning and normally forget to turn it off until i get to work - about 20 mins.. taMaurice
