Trying to sort this out in my head before I have to fit a new head.
Symptoms.
Overflow tank full,and coolant level inside of pressure cap low.
To fill back up to pressure cap level it takes about a cup full.
Rear heater disconnected and when level is ok plenty of heat from front heater.
Plan of action.
Check footwell carpets for an damp patches,which would indicate heater matrix leaking.
Take pressure cap off and pressure test system to look for any leaks.(fix any that are found).
Check overflow hose for perishing and replace.
Check pressure cap seals and mating faces.
If all the above appears ok then it would be prudent to change the pressure cap as I have no way of testing that.
Then I assume I am getting into the possibility of replacing the head.
Has anybody got an idea of how long the heads that were changed in Japan should last?
Symptoms.
Plan of action.
