So I swapped the head on my 2.4. I know the head is torqued properly and the timing is set right (checked it multiple times). I have good battery voltage and the vacuum pump is hooked up. The glow plugs are also hooked up and working properly I still left the A/C off and rad out to try to see if it starts. it just cranks and the tach jumps up to about 1000 rpm as it tries to start.
It seems that it isn't getting fuel to the injectors. when I pull the line off the injector and crank, no fuel comes out. I'm not 100% sure if the lines are in the right order on the back of the fuel pump, I just put them on where they lined up best.
I also did break a piece of a small brown thing below the intake. Just snapped the nipple off and epoxy'd it back on carefully not to block it off. It was a line from the intake and another that goes to the EGR.
All of the connectors are plugged in. Any ideas what to check?
EDIT: the fuel primer is nearly new and working properly, the fuel pump is also pretty new.
