new surf woes
This topic is closed.
    Originally posted by NiftyNev View Post
    I would not attempt to restart that engine until the timing belt was checked. It may have skipped a tooth or two or worse.
    will pass that on as well Nev. thanks
      Do a code check as Tony suggests. If you get a Timer Control Valve code then I would check the belt for sure.
      http://www.toyotasurf.asn.au/forum/viewtopic.php?t=729
        Hopefully it will not be too serious but keep us updated. I wish we had a surf mechanic somehere in Worcestershire.
