hubs
  • hubs
    I had a wierd knocking from the front end of my 1991 hilux ssr (import) yesterday, looked all over and couldnt find anything really obviously loose. Well today i went to park up and the front passenger wheel fell off!!!! luckily the truck sat on the wheel so no damage there but some studs are bent and 1 has sheared off. Does anyone know if the studs are pressed in or bolted/screwed on. All the wheel nuts had come off, which strikes me as wierd and i am not sure how it has happened. All advice is welcome.
    http://www.roughtrax4x4.com/?doc=16&cid=146&vid=722
    and
    http://www.roughtrax4x4.com/?doc=16&cid=146&vid=937
    Eat.Sleep.Surf.Repeat.
      You have to remove the caliper and hub. Split the disc from the hub and press out the studs.
      I'd be checking everything for bent bits.
        at a guess someones either been trying to nick the wheels and been disturbed or someone doesn't like you and undid the wheelnuts.
        wheels don't just fall off
