Anyone know if the gaskets are the same for the 2L and 2L-T 1st gen? As the one listed on roughtrax only says 2L diesel?
Head gaskets
There are two types of 2L motor, I think Nev mentioned it before, you need to know if you have a the newer OHC motor, or older one with rockers.
The easist way to tell is the old motor has three bolts down the center of the rocker cover, newer one has loads of both round the edge.
In the pickups 84-88ish is the older version, 89-on the newer one. But I've seen 87-88 Surfs with the newer motor. They use different gaskets.
Look at MK2 pickup stuff on Roughtrax, YN or LN65, 84-88 if its the older motor.4x4toys.co.uk - Keeping you on and off the road...
Cheers mate, i've ordered the full kit, head is in at the machine shop at the moment so fingers crossed its all good lolOriginally posted by NiftyNev View Post
