Turbo feed and return pipe required
  • Turbo feed and return pipe required
    HI all.
    Can anyone assist with a used turbo oil feed pipe that has the return on it to. It sits on the underside of the turbo when mounted on the manifold. Its a small steel like pipe. I had to cut mine in two as it was a complete bitch to remove.
    If anyone can help can you please PM me or post here with details and price. Im needing this pipe quite urgently after a head rebuild. This is all thats holding me up from finishing the job.
    Vagrant has suggested a flexi pipe repair with flared ends on the pipe and a flexi on a compression joint to mate the two up, but I would rather keep everything original looking.
    Thanks in advance.
    hi 2.4 or 3.0 litre have both email [email protected]
      Hi Lord, its for the 2.4. How much please?
