Hello,
It's been a few years since I sold my last Surf and I've started looking for one again. I've got my eye on one for a cheap price but it's got an auto tranny problem. I've searched for this but found nothing, so here it goes:
Apparently it developed a fault and would try to start in 3rd gear. The seller said he replaced the shift solenoids and that corrected the gear selection problem but now when it tries to shift into 3rd it goes into a "false neutral"?
He states that the fluid is not burnt and that it shifts fine manually. He said that since he is now back in school he doesn't have the time or money to keep troubleshooting it so he's just selling it cheap.
Now my old surf was a manual, and with all their cooling problems thats what I'd preffer, however they are scarce here and if I can fix this rather cheaply/easily then it's too good of a deal to pass up.
I understand that you can unplug the tranny and manually shift through 1,2&OD (which it sounds like he has done) to prove that its mechanically working good. What's the possibility of the 3rd gear being mechanically damaged? It seems the ECU is typically at fault for not shifting into OD but what about 3rd gear?
I haven't driven or seen this vehicle myself yet as it is a couple hours away, I'm just working with the info that I've been told about it.
Thanks for the help,
hopefully it's worth all the time I spent trying to remember my old user name and password!!
One makes for a really cheap easy to fix truck, and the other needs a new gearbox.
