Was having a cold heater syndrom last night (first time I've ever tried the heater to be honest) and of course no heat. There was a new 0.9 bar rad cap fitted when I got it, but when I took it off this morning about a litre of coolant came out, so obviously it's still pressurised from lasts nights running around.
So after reading a few threads on here regarding burping the system, I had her up on car ramps, rad cap off and running with the heaters on for about an hour, and all it did was push more coolant out of the filler. All heater matrix pipes are cold so it's clearly an air lock, but even up on ramps the pipes sit way higher than the filler. So figured I'd switch it off, leaving the cap off and try again later (when I've got some Hylomar and some spare jubilee clips). Only after it was switched off did the level drop enough to put some coolant in.
I've heard of people leaving the caps off overnight to let the air out, but it seems on these if the engine is running, you've got no chance of bleeding without an air valve in the topmost heater hose. Does that all sound about right? My Supra is a pig to bleed too, so guess this must be a running Toyota theme...or maybe gravity works differently in Japan...
