hiya, i have a reciept from the guy i bought the surf from for a new head but it seems a bit cheap.
its from PEERS PARTS in london
"new toyota head & gasket bolts" £175
this would make it less than 2years old.
does this sound right for a new head?
and anyone know if it'd be any good?
because i think mine might be knackered
its "supposed" to have had
new rad cap
new water pump
new thermostat
drive belts
new timing belt
new rad
new temp sender
n/stk temp switch (whatever that is)
new alloy coolant pipe
it really shouldn't be over heating with the above new stuff should it? unless he's done a crappy job?
(forgot to mention the guy i got it from was a fitter by trade with use of a pro workshop so might not have needed all the gubbins that "should" come with a new head.
new rad cap
new water pump
new thermostat
drive belts
new timing belt
new rad
new temp sender
