Morning folks,my 2.4 93 import surf has been sitting on my drive for over a yearafter badly overheating,I was told by everyone I asked that the head was gone,2 weeks ago after following the tips on this site i changed the coolant and thermostat,the beast is running and the heating stays midway at the min.anyway i got brave and bought a oil filter but can find no idiots guide to change the oil,i crawled under the drivers side and found a oblong box the bung was 14 mm i undid it and oil came out,im getting good i thought the oil wasn't black more tinged with red is this the wrong oil? and would there be another sump before the oil sump,i really haven't a clue i turned the key but didn't engage the engine the oil shows empty where as before it was 1/2 way.
also is there a another filter that looks like the oil filter?sorry for being so thick but as a mechanic I make a great pizza.thanks in advance.
3 posts at the same time, creapy
many thanks for the quick replies,if it wasn't for this site she would have sat on my drive doing nothing just because i don't have a clue and the local garage just said it was the head without looking at her,it might still be ,but at least i will now be able to know for sure once i get these little jobs done.
well the first oil was the atf so thanks to my ignorance i have now managed to change that plus the oil and filter,however now the bugger won't start ..which is strange as it has a new battery and worked fine before the fluid change.all the lights and windows work,,but when i turn the key it just clicks.
Glad it turned out okay! Some good advice would be to add your car details into your profile so similar mistakes MAY not occur.
