gear box
  • gear box
    Lately my beast is taking a few seconds to engage into gear at junctions and such, this only seems to be happening when its cold? Any ideas?
    G
    Always assume the worst.....Anything less is a bonus!!
    is it auto or manual?
    if its auto check to see of there is enough oil in it
      If its manual check the oil too, theres a size 24 bolt on the side of the gearbox and you open and remove it in no more than 3 turns. If oil trickles out its ok, if not then top it up until it does with 80/90.
      Check the levels in your master cylinder reservoir, top up with brake fluid if low. If below the min level, worry why and find out. You should find out how to bleed it, its a DIY's (yourselves ) job. Your master and slave might need replacing.
      Then theres two bushings in the lwr gearlever area that are very cheap to replace.
      Thats all there is to it (
