I have been doing a load of maintenance work which includes replacing the thermostat, rad cap and usual flush/re-fill of coolant system.
When the re-fill of coolant was almost complete, i fitted the rad cap and removed one of the hoses from the heater control valve (on the bulkhead)to finish topping up through this hose to eradicate most of the air. While doing this i noticed that the resevoir was filling via the "vent" pipe below the rad cap.
Is this normal?
I thought that the rad cap sealed the system up untill a certain pressure and also allowed return flow under vaccum.
I tried it with the old cap and still the same.
Am i being thick? or is there something wrong?
dazza
Is this normal?
dazza
