 Hi all,
 Hi all,I have a `93 2.4 surf SSR-X which started dumping about .5 to 1ltr of coolant into the expansion tank about a month ago.Replaced the coolant filler cap and all seemed well for a while. Now its started doing it again. Took out the thermostat and tested it - it wasn`t opening until 97 deg C - so cut the middle out and refitted the outer ring so seal would fit in housing. On the next drive the temp gauge went up to half way mark after driving for a couple of miles, which I thought was odd with the `stat removed, continued to drive for another 60 or so miles. The engine did not overheat at all andd heaters were hot when tried. Still found coolant had dumped into the expansion tank, about .5 ltr. Engine is not exhibiting any headgasket sympyoms. Checked flow thru rad and all seems ok there. Every time I drive it between .5 and 1 ltr of coolant gets dumped into the expansion tank and i`m starting to clutch at straws.
The cooling system does not seem to over pressurise, viscous fan coupling is ok, electric cooling fans are working. The new cap is genuine Toyota and has a three way seal type arangement to allow the cooling sytem to draw coolant back into the rad from the expansion tank but it doesn`t seem to be doing this - has anyone had a dodgey cap before?
Any one got any better ideas ?
Help!
Eddy.
						 GOT NO COWBOYS HERE?
