Hi everyone.
My 1990 2.4 TD has just developed what appears to be a gearbox problem. When it is cold it seems to drive and change gear fine, but once it is warmed up it wont change up through the gears and will only crawl along at 20mph. I have tried manually going through the gears, pressing the economy button, in and out of O/D and revving the engine and dropping the revs, but all to no avail.
I have checked the transmission fluid, whilst the engine was warm and running, and the level is fine. I have just returned from a local test drive to try and pinpoint the problem. I did all the above, but I just had a long tailback behind me, and to put the icing on the cake, it wouldn't reverse so I had to push it onto the drive!!!
It has just come back from the garage last week, where it had a new radiator and oil cooler fitted. Is it a coincidence?
Any help is greatly appreciated.
Regards,
Steve
Regards,
Steve
) before allowing the transmission to shift into top gear or overdrive, it may have something to do with your problem.
I have a very similar prob, my engine check light is on almost all the time yet mostly drives ok for short runs, but when goin down the M6 after an hour from start mine went down to 30 (oh gods the embaressment) soon as I got off M6 she seemed to run ok again, then drivin back - torrential rain - flew back, pullin at 75/80 mph uphills goin back to leeds. I'm goin down south again weds and dreadin the same thing happenin, any ideas on why she is doin this or what I can tell my machanic to look for?
