Got a small weep from behind starter motor, does anyone know if there is a core plug around this area as I can't feel or see one. Thanks in advance.
Water Leak
There's four in starter side of block. There's also three or four in that side of cylinder head below the manifold. Above the starter is also the ECU Temperature Sensor so that's another possibility. Could it be a leak from hoses that go to the underside of manifold?
Thanks for that mate, at this point I'm not sure which of these it could be, I changed the head about 18 months ago so I hope its not the head at fault, if I had a neck like elastic man I could maybe see better, it goes for MoT next month so may wait till its on the ramps, loses about 1/2 pint every 150miles/week from the expansion tank.
