Hi folks
As back up to my post about curious coolant leak.
Had my rad sorted and refitted, the hoses on the rad are still highly pressured.
The mechs at the garage filled the coolant back up- hopefully without airlocks.
There is no other signs of anything wrong except this high pressure in the hoses.
Does anyone have any info on this? What sort of pressure do others have, what is the pressure supposed to be.
How much resistance on pressing the hose is normal?
What pressure does the rad cap rate and how does this work?
One point I would like to check is that the mechanic reckons that I should run without the stat as he believes this may reduce the pressure in the hoses by allowing a free flow round the system.
Any thoughts or advice would really be appreciated as I want to rule out a warped or cracked head(again) or a porous block.
Thanks
Ronnie
Thanks
Ronnie
