Hi guys, I'm just doing my Timing belt and water pump today, I have it stripped as far as needing to get crank pulley off, I have a Harmonic puller and was wondering is it possible to remove all in one go or do I have to remove the 4 nuts and remove the outer pulley first? Problem is that some clown has rounded off 2 of the 4 totally! No socket will fit. and hard to get into
