Hello All -
A couple weeks ago the fan speed control switch on my climate controls (Heat/AC) started acting flakey, not working sometimes or not on some speeds, then it completely quite. I took my unit out and apart:
Here's the damage:
Looks like the switch fried and melted. From some reading I've done this could be caused by a resistor in the heating system? My question is, if there is, does anyone know where this resistor is located or how to check it?
I've tried locating a replacement for the whole climate controls here locally but that's impossible, I'm in Manitoba Canada. I'm having an importer in BC try and get me the part from Toyota Japan. Do any of the 94-96 surfs/4runners/sr5 use this unit, most I've seen have strictly mechanical units. Is there any way I could fix this myself, or even get the fan on at full speed? It's still -30 here so it's too frosty to be driving around with no heat.
Any help will be greatly appreciated. Thanks in advance!!
Cheers!
-Steve
Here's the damage:
Cheers!
-Steve
