Gave the newly aquired Surf a service at the weekend. All went according to plan - pretty easly to work on really. Did the radiator flush - when I'd removed the bash plate I discovered what I guess is a large oil cooler fitted at angle directly underneath the main rad (almost as big as the main rad), which made draining the rad a bit of squeeze, and only done through the tap not the lower hose (as I couldn't get to it) Is this standard on 1992 2.4? I'm guessing it's for the gearbox oil? I took a photo of it (which I'll post later - I was suprised to find it!)
Oh, another quicky - how do you go about removing the fuel filter?
