I had to remove and rebuild my engine, which I have done. Now I've put the engine back in I'm having all sorts of problems with the electrics.
First problems were when I had the engine out, I wanted to lock it up and close the boot so I reconected the battery closed doors and locked everything with my key fob, when i removed the battery the alarm went off, so I made sure no wires were touching anything and left the battery on. About a week later I wanted to get back in but when I pushed the fob nothing happened, so I opened the door manualy and the alarm went off. There is a little thingy to push in to deactivate the alarm so I did that, peace.
Next thing I noticed was the heater plug light was on when there were no keys in, strange so turned ign on, light went out, ign off light on.
Decided it was probably all because the engine was out so left well alone. Now the engine is back in, I still have no life in my key fob, the blooming glow light is on unless the ign is on then it's off, the alarm is deactivated but I have to push the imobilised/ alarm deactivater thingy in it's plug to get engine to turn over. Engine turns over well but doesn't give a hint of firing. Think I have made a mess of something, one other thing I tried today was to use a bit of wire from + terminal of the battery to the heater plugs to try and warm them up to start her up it shorted, I didn't think that should be earthed. Hope someone can help before it has to go to a garage and costs me a fortune, is this all down to the alarm?
