Yesterday morning my surf started, sat and warmed up for a few mins then drove about 3 miles when i noticed the temp guage was at max, stopped and found it was boiling and steam coming out of the expansion tank, took the radiator/water cap off to release the pressure, let it cool down for a bit then filed it up with water, ran fine for the rest of the day and put it down to the fact that it was a cold night and didnt have enough anti freeze in it.
This morning went out and checked to see if it was frozen before turning the engine and found pipes frozen not solid but slushy, got blow torch under the engine and thawed the whole thing out, drained as much water out as i could and put load of anti freeze in, bit late but yea i got it running and all thawed out and its running now with heat coming from the heater.
Problem is its running like a bag of shit, engine check light is ON, ticks over fine but give it a little throttle and thats when the revs go up and dont come back down again and all i get is a load of black smoke and i have to turn the engine off then start it again to get it to idle.
I took the thermostat out of it yesterday, maybe thats why the light is on and why its idling high with black smoke? any ideas?
