Hi Folks,
I need to remove a seized rear wheel(n/s) which probably by way of oxidation of the alloy and the steel hub has caused it to seize, several attemps have been made to rotate the wheel as the tyre is struck from the inside,wd 40 sprayed between hub and wheel have also come to no result.
I'm thinking of using a puller to free the wheel,any further suggestions or tips would be greatly appreciated.
Thanks, Rockjasper
Thanks, Rockjasper
