Hi,
I have a 91 2.4 and when it has been sat cold say over night she needs a coupld turns of the key and foot on throttle to start. When she does start its very smokey and runs rough but then after 30 secs or so runs sweet.
I thought that this may be the glow plugs and have tried to test them but not sure if I have done it right. This is how I did it - I didnt remove anything I just put my mulitmeter on the top of the plug and then earthed it somewhere in the bay, I left the ignition off and took the reading on the 200ohms setting. I got a reading of around 1.1 - 1.2 ohms for each plug.
If this is the case do they not need replacing? Or have I done something wrong? Or does anyone have any suggestions as to what could be causing the issue?
PLEASE HELP!!! I am not very mechanically minded so sorry if my question seems simple!! Thanks very much!!
Ed.
Ed.
the fuse terminals are touching as a quick fix before I tackle the annoying issue of replacing a fuse (why they could not make this as easy as pulling it out i do not know).
