Hello again, i posted a while back about my surf fitted with a brand new head but still pressurising. Took head off, actually it slipped off, the whole gasket was soaking and rusty. Head is back on after head skimmed and new gasket, only fitted this week, battery to weak to fire. Re-charged battery again and nearly started, will repeat procedure tomorrow after a re-charge. Hopefully the re-fit will rectify the overheating.
My gearbox (auto) was replaced due to my original dumping all its fluid. Bought a running roadworthy surf for the engine and gearbox which changed gear perfectly, engine was underpowered, no overheating just loss of power, suspected turbo, turns out to be another cracked head between every valve.
My problem is after fitting the gear box, wired all up, it constantly jams in park, cant remove the key from ignition till i remove the battery.
Any help will be most appreciated.....
