Following my glow plug tip saga, I'm going to whip off the rocker cover to have a closer look.
Does anyone know where the valve shims sit in relationship to the cups. Are the shims on top between the cam and the cup or below between the cup and the valve stem.
Also, is it possible to reverse a worn shim and use the 'clean side against the valve stem/cam?
TonyN had this link in a previous post but doesn't seem to work
http://www.afm15.dial.pipex.com/surf...0Clearance.pdf
yeah so was I
