Throaty Air Inlet
  • Throaty Air Inlet
    Have recently noticed an increase in 'throaty' engine sound, like if you've blown a hole in the exhaust some point. Quick check and it's coming from the air intake and reverberating in the filter housing. Not that noticeable when first warming up but more so when fully hot. No excessive smoke out the back end at the moment.
    Is this a sign (or sound) of Turbo Trouble ahead??
    Look out! Ee
    Could be just the air filter element breaking up or not sitting in the housing correctly. Some people have had troubles with the filters being slightly too small and vibrating in the housing.
      Thanks Andy but I tried that one. Loosened the end of the intake connetion away from the housing and a deep rasping is coming from the end of the intake pipe, sounds like a blown exhaust noise. It doesn't seem to be affecting power but I have noticed the turbo needs a little heavier foot and a bit more coaxing to cut in these last few weeks...hmmm
      We'll see
      Look out! Ee
        any connections to the turbo loose,any pipes leaking
          just sounds like un muffled induction noise to me... sure the lid's tight on the air box?
            I'll give it a good once over tonight and advise
            Look out! Ee
              You have a turbo on your 2.7???
