This may be a stupid question, but I don't know a lot about surf's yet!
If your head cracks and you then do whatever is needed to replace/repair it at vast expense, is that the end of all the problems associated with 2.4td engines, i.e. is it likely to crack again? (Assuming you take all the necessary preventative measures as well, i.e. change the coolant regularly, etc, etc.)
MJ
MJ
