2.4 injection pump
  • 2.4 injection pump
    hi peeps well its sunday and my truck decided it was having a holy day!!! in effect it developed a leak from the IP i have replaced the top seals and thought it was done as i haven't seen any drips on the floor but yesterday i took it for an oil change at a friends barn with a nice clean concrete floor needless to say we noticed a drip or three i have removed the aircon assembly from the underneath (didn't work anyway) which allowed me to have a proper look and the sump is wet with diesel now after i've driven for about five miles it doesn't appear to leak but less than about a mile and it leaks i'm not wanting to take the IP off if i don't have to but knowing my luck it is probably the most awkward seal on the pump does anybody have any idea which is the most common seal to fail apart from the top seal as i have replaced them already. i really don't have the time for the truck to be off the road so i was thinking of getting a s/hand IP and replacing the seals in that first and then change the pump in one go so if anyone has a IP thats cheap i would be interested or any info that will help tracking down the leak i need to stress that at the mo the truck has no issue's with running it does miss a little when starting because of the leak allowing a little drain back first thing but ok the rest of the day
    I have a 2.4 fuel pump still on the engine if your needing it.£80 delivered for you.Its a good pump as the engine is/was in full good running order before being taken out of the truck.
    I think if you have done the normal seals that go then it will be a pump out job to sort the rest
      hi mate i think i need to set up an account with you!!!!! ok mate i think i still have your email but can you resend it just in case please and thanks for the reply mate
        email/paypal is [email protected]
        Just let me know if you want it.I will get it off ready anyway so then it can be sent straight away for you.It will be sent APC 24hr delivery
          yep i'm just going to pay it for it know
            Ok right on.I'll get it off tomorrow and if its not sent tomorrow it will be sent Tuesday and be with you Wednesday
              hi richard payment sent to you
                Cheers Tony.I'll let you know what day its sent so you know when to expect delivery.Will someone be home either tuesday or wednesday or i can send it to your work
                  nah richard i'm not at work so i'll be home most likely or the wife will be in so no problems mate cheers again
                    fuel pump is all ready to be sent tomorrow for you and delivered Wednesday
                      ok richard thanks. now all i've got to do is work up the energy to do it.....
                      hopefully it shouldn't be too bad to do shame you can't leave the T/Belt in situ like the peugeot 1.9 diesel it would make life easier then the crank pulley could stay on but heyho thats the way it goes toyota making life diifficult....
                        hi richard the pump has been fitted and she works bob on mate i haven't took it out yet thats going to be later tonight or tomorrow now. not too bad to do after all four and a half hours start to finish aint bad took two of us due to my disabilities but job done
                          Hiya.Glad the truck is running ok now.All you got to do is go out and enjoy it
