Just started happening randomly.
I'll be cruising at highway speeds with no major throttle and it will start randomly surging between 2800-3000 rpm.
Any ideas on what the problem might be? Idles just fine, though when you start up in the mornings it can be really rough some times when it is cold.
I've replaced the glow plugs, air filter, fuel filter. 2 Years ago I had the head re-done, with new belt tensioner, idler pulley, water pump, thermostat, gasket, etc etc.
