I am still without my Surf after 2 years at different garages. The problem now seems to be a fault in the engine loom. Has anyone got one or can anyone tell me of a reliable source? The car is a 1992 LN130.
2.4 Engine loom
Hi Peter just to let you know that the courior is picking your loom up from me tomorrow so you should have it within the next few day.
I have given you both parts of the loom so withever bit you want you will be covered.If at first you don't succeed.........give up.
Possibly oil pressure sender unit?Originally posted by Benson View PostThanks Brad, done the trick. Car now runs beautifully although the engine check light still comes on at idle. It seems to coincide with the oil pressure dropping to about a quarter on the gauge. Any ideas?
Pleased the wiring loom done the trick though.
