WHAT A PIG!
this is NOT an easy job, is it! Well, I've removed the fan, belts, rocker cover, air tubes from turbo, all the gubbins round the right side, cam belt off, and all but one bold from the exhaust manifolds - need an 8mm star socket for that as its just too rounded off for an 8mm hex.... got the head bolts out USING A 4 FT SCAFFOLD POLE TO GET THE LEVERAGE!
as to whether or not the head has gone, well, the valve cams are all rusted up, so there is water in the head for sure!
Just got that last manifold bolt to get out and put my engine hoist together then i'll get it off for inspection.
New gasket and bolt set due tuesday. Stormy Head already here, which is gonna need a clean as there is rather a lot of what looks like metal gritty stuff in the oil... we'll keep you informed. Oh and stormy, was it your brute force that broke the front lifting point off where it bolts to the head? or some other overly zelous mechanic?
enough for today folks! im nackered.
