ok this has been done befor but i need some help..
I had to put in a new rear wondow as the other one was stuffed,,
After putting it in i realised the lock lever would not move up or down its stuck in place(the plastic one inside the trim)
I also noticed the motor had decided to poo its pants which i could not understand
Also i get this horrible bleeping noise i have never heard before when i try to close the window(which it does not by the way)
I need help i got an open window,that bleeps,its winter here and very cold. i need to know how to put a new motor in as i could not see the 3 screws ive heard about,, and i also need to know how to pull the plastic trim of the top of the tailgate (the bit with the handle in it)
Thanks in advance
Thanks in advance
