Hi does anyone know where I can buy a new/used (pref 2nd hand as I cant afford a new one off Rough trax) fly wheel from for a 2.4TDI manual, I really need one asap. cheers
Fly wheel required
If you only buy the flywheel second hand make sure it's the right size for your clutch.
The pre-facelift 2.4 is 225mm and the post-facelift in 240mm.
I bought the solid flywheel kit and it comes with the 240mm clutch therefore upgrading my pre-facelift truck with a better clutch and a flywheel that is bomb proof (not to mention the fact that the full kit is cheaper than the original dual mass flywheel alone).
Thanks,
Ray.I've got a plan and it's as hot as my pants!
thanks ray, where did you buy your fly wheel then?Originally posted by lord_flashart View PostIf you only buy the flywheel second hand make sure it's the right size for your clutch.
Thanks,
Ray.
Fly wheel conversion kit!
Hey mate. The conversion kit is best... Just done one myself 4 weeks ago! I found milner4x4 cheaper than roughtrax, plus you can order the kit throuh mill auto which gives piece of mind if you need to take it back! Worked out 495 then i was lucky enough to know a greace monkey that put it in for 100quid. If you need more info let me know. Cheers
