Hope you can shed some light/impart advice for me.
I've had a leaky injector on my surf 2.4L, it got alot worse a week or two ago and there was a clear fuel leak onto the floor. The car got harder to start lot's of turning over and then would start with a fair amount of smoke. Guess this was air pulled into the cylinder as fuel leaked out when engine not running.
So got the part and local garage replaced it, all seamed fine. For a day. The garage (A good bloke IMO) said that the starter motor was on it's way out and that the solenoid was burnt/burning out. From all the turning over of the engine?
So tried to start it last friday pretty much nothing on the key at first and then a vague attempt at turning over. But would not start so reckon the starter motor is dead.
Is there any way of getting the old hilux going without the starter motor or will I need a tow or trailer to get me to the garage? Isn't towing auto's a bit iffy?
Is changing the starter difficult?
Any advice gratefully recieved
Alex
The car was running fine once started, smooth and not billowing out smoke once going.
Alex
