over the last few weeks its been harder to start the 2.4 surf...turn over for ages then fire up in a cloud of smoke grey mostly ,,it starts first time from hot ,,,so im thinking heater plugs ??? but does it really need heaters in this weather ????
starting trouble
Did you put new or used plugs in? However if you checked them before you put them in then they must be ok whether new or not.
Make sure the bar is tight on the plugs as the plastic caps become loose and don't tighten the nut type thing up properly....if that makes sense.Last edited by Justbrad; 13 May 2010, 20:08.If at first you don't succeed.........give up.
i would get a new air filter put in anfd also a new fuel filter.Fill the fuel filter with redex or even better atf and then fit it.Take the truck for a ruddy good hard drive for a couple of miles to give the fuel system a good clean outOriginally posted by arron View Postwell morning came and though it started a lot easier it still smokes a bit and seems to run on 3 pots for a bit then all runs smooth and smoke stops ?????https://www.facebook.com/groups/henpals/
by atf do you mean auto fluid ??? does this work ???Originally posted by stormforce View Posti would get a new air filter put in anfd also a new fuel filter.Fill the fuel filter with redex or even better atf and then fit it.Take the truck for a ruddy good hard drive for a couple of miles to give the fuel system a good clean out
Hi arron,Originally posted by arron View Postby atf do you mean auto fluid ??? does this work ???
ATF, automatic transmission fluid.
I use redex diesel fuel treatment at every fill, once a month I
put about 250ml of ATF in as well, and yes it works fine.
It may even stop the injector pump seals leaking as well.
Hope this helps.
Gman.If it aint broke, keep goin' till it is.
