after blowing the head gasket and cracking the head i was a little teasy, now i have had the rad recored aswell because the pipes were corroded and blocked causing more overheating. it seemed to be runnig okay untill yesterday the old girl got very hot and pis#*d a load of water out of the expansion tank. have bleed the system a couple of times hoping it was a air lock but its still getting hot on uphill and tickover, nothing blocking the rad and fan seems to be okay. the mechanic i went to tested the coolant and allthough the test wasn't crystal clear it indicated that there was gas in the system, he thinks it could be a cracked engine block but isn't sure,
good old trusty 2.4s any suggestions?
