Hiya,
I think I've got three relay related questions, but any advice will be much appreciated
OK, when I park up in the sun and my truck gets quite hot inside, the tailgate window stops working...I don't mean you can't see through it anymore, I mean it refuses to wind down from either the swich by the gear sticks or the key in the tailgate. I know there's a relay at the back somewhere, as you can hear it clicking when the window *is* working, but it doesn't even click when the truck's hot - does that make sense? Can anybody tell me how to fix it, please?
Second one, then - my air conditioning isn't working
I had a Surf before the one I have now and I remember that, when you switched in the AC, there was an appreciable drop in engine revs - I even had snow coming out of the vents once! This one, though, does absolutely nothing when you switch in the AC - the light on the switch comes on, but no drop in revs and no cold air
I've looked for a fuse but I can't find a specific one for the AC and none of the fuses I found were blown anyway. Again, I'd imagine there's a relay involved here, but I can't hear one switching when use the AC switch - any ideas?
The third one's more of a "hmm, that's interesting" than a "why doesn't this work"... I've noticed that, when I put the accelerator down about half way, there's a relay click from under the dash somewhere - what's it doing? What's it for? Where is it? Why is it switching willy-nilly and the relays I actually *want* to work are doing b*gger all?
So there you go, thanks for any help
All the best,
Paul
I've looked for a fuse but I can't find a specific one for the AC and none of the fuses I found were blown anyway. Again, I'd imagine there's a relay involved here, but I can't hear one switching when use the AC switch - any ideas?The third one's more of a "hmm, that's interesting" than a "why doesn't this work"... I've noticed that, when I put the accelerator down about half way, there's a relay click from under the dash somewhere - what's it doing? What's it for? Where is it? Why is it switching willy-nilly and the relays I actually *want* to work are doing b*gger all?
All the best,
Paul
