trucks been running great for the last three weeks since we swapped the head, rad, water pump and timing belt.
headed out to go to work this morning and everything was fine as usual for the first 2 or 3 miles then i notice steam coming from the passenger side of the bonnet. i panicked then looked at the temp guage and its off the chart.
slowed down from 65mph to about 40, as theres no where on that stretch of dual carriage way to pull over right away, and the temp guage goes back to normal but still billowing steam out. i managed to pull off and park up (it didnt give the engine warning lamp or cut out like it did when the head/gasket/rad popped last time). opened the bonnect and one of the hoses benath the t-stat had blown off which was where the steam was coming from. i let it cool a bit then refitted the hose and checked the water level....lots in the expansion tank but none visible at the t-stat filler. topped it up with water and fired it up again. started first time and sounded normal and the temp guage read normal. gave it some throttle to see if anything would come out the filler and after a few mins it began to blow steam like a choo choo train. turned it off and topped it up and it did the same again.
i think, but may be wrong, that i have some frozen coolant somewhere in the system. i only had 3L of antifreeze at the most in it and the rest was water
the buggers sat in a little village a few miles fom home until i finish work and fid a way to get it home.
i think im doomed with this truck
