Having a hard time removing the bulkhead pipe to flush out the matrix,dont want to pull too hard incase i damage the hose itself, any suggestions would be greatly appreciated
Bulkhead pipe removal
Loosen the hose clip, slide it back and give the hose a twist to break the seal then it will pull off.Originally posted by bornwina View PostHaving a hard time removing the bulkhead pipe to flush out the matrix,dont want to pull too hard incase i damage the hose itself, any suggestions would be greatly appreciated
If you use grips of the hose end, don't squeeze too hard as you'll crush the brass tubing.
