Bulkhead pipe removal
  • Bulkhead pipe removal
    Having a hard time removing the bulkhead pipe to flush out the matrix,dont want to pull too hard incase i damage the hose itself, any suggestions would be greatly appreciated
    Loosen the hose clip, slide it back and give the hose a twist to break the seal then it will pull off.
    If you use grips of the hose end, don't squeeze too hard as you'll crush the brass tubing.
