Hi my Hilux surf '93 import 2.4 ssrx auto isn't starting now it's got cold.
I had a problem getting it started on wednesday when it took several trys and turns of the key to get it started. I drove it a little parked shopped and went back and the same thing then I drove further and had batteries checked at kwik-fit and they were OK not perfect but guy said enough to start. The Hilux then started fine when I started it after battery check. Guess that was because the car was warm. Then went and shopped for a few hours and it was a struggle to start again.
Now I've come to try this morning and it just won't start up. It's colder today than wednesday so think that may be part of the problem.
I've recently had new glow plugs so they should be OK, however I've never ever had a beep when my glow plug light go's off - should I have one? my fuse seams fine.
Should I try getting a battery starter (or a jump start) and topping up my oil as it's a tad (4 months) old and that could be thickening. My thought was some more Ogomph for the battery and a top up with new oil may help for now and the next few weeks.
Cheers Folks
Cheers Folks
