Ive been woundering about these head probs mentioned on this forum. As far as i know a motor fitted with a turbo should not be switched off immediately. It should be left to idle for a set time say 20 secs. If you switch off straight away, especially after a high speed run, you could put undue pressure on the head/gasket eventually causing it to fail. I don't think this applies to the intercooled versions though.
Just my opinion.....................mu ncher
