Hi All,
really easy questions for you!
1. My front heating gets slightly warm but not hot, slider works, pipes at bulkhead get hot etc - is it likely to be an air lock?, if so what is the best way to fix?
2. My rear heating doesn't heat - just blows, is there a seperate matrix from the front Matrix? would that need bleeding too? - or is that likely to be a blocked pipe?
I know other people have had similar issues on here but i can't find how to bleed the matrix (even with the haynes manual), is it at the bulkhead?
