hi guys! my surf is going bananas!! a while back the speedo stop working, and the od light flashing, although the od works fine(it disconnect when i press the button,. I have removed and cleaned the speedo sensor located near the prop shaft i have checked the ect unit by the fuse box and i removed and checked the speedo itself looking for burned circuits with not luck!!can anyone help?
Speedo!!!!!!!!!
Welcome to the 'no speedo' club. Me too!
In my case it's because I'm too lazy to look at the more difficult to get at bits. Had the clocks out - no issues, gave the connectors on the sender a cursory inspection - no issues. Guess I'll have to get dirty and cold one of these days...
Til then, there's always the satnav - and its not an MOT fail.Cutting steps in the roof of the world
Been there, no probs with the flexi circuit board on the back. I'm wondering if my electronic kmh / mph converter has died... I'll reconnect it as kmh, bypassing the converter and see if that sorts it.Originally posted by Albannach View PostI had the no speedo and flashing OD light on my 2.4, it was a burned out track on the back of the speedo its self.Cutting steps in the roof of the world
