I have a 92 Hilux LN130, 2.4LTE. When I purchased the vehicle from an importer, the headlights were supposed to be all switched over to Canadian standards. I had an issue that required me to access my headlights and bulbs and what I have discovered is a bit of a mystery...
The importer jammed a light bulb into the headlight that does not seem to fit. The plastic locking ring that holds the bulb is broken and the bulb is loose. I recently had some electrical work done on the truck and the electrician was not sure what bulb it would take to make it all work. So here is the question...
Did my Hilux take a different bulb in Japan? Or does the truck actually take a 2004HB? I don't have the time to take it all apart to have another look at until I get to work and then I have no access to parts since I am way out of town. Does anyone know what North American bulb this vehicle takes since it would seem it is not a 4Runner bulb. Any help is greatly appreciated.
I can buy everything I need before I leave town and fix my crappy headlights!
