Hi guys,
I've posted on here before about having a turbo problem, in that my truck has absolutely no power, no speed or anything, just completely gutless and the green turbo light has never lit up under load since I have owned the truck. I have come to my own conclusion that it isnt the turbo thats knackered, and no, it isnt the vacuum pipe going on to the turbo sensor. However, I believe that I have a fuel leak from the injector pump and that my truck is under-fuelled. I compared it to a mates truck, which, when the throttle is pressed hard and suddenly, coughs out a bit of smoke indicating the excess "dump" of fuel, but mine just revs up fairly slowly, and takes about twice the time for the revs to drop back down to idle speed..... Could this be a cause to loss of power in the truck, perhaps if air is getting in too? Is there anyway I can increase the fuel supply?
Has anybody got any other suggestions as to why the truck is so flat and gutless and cant even switch the green turbo light on?!
I would really appreciate it since I seem to have worn out all the suggestions on the air/turbo side, including the various vacuum pipes and where they go to!
Many thanks
Many thanks
