1993 Surf vibrating
  • 1993 Surf vibrating
    Hi everyone,
    My 1993 2.4 auto surf vibrates under braking when driving forward and when I put it in reverse and sometimes when it is parked facing down hill when in neutral.
    I have replaced the gearbox mounting bracket but no joy.
    Please help as I am driving an Escort van and I prefer the surf .
    Thanks everyone.
    it sounds very much klike warped disc.You can get them from www.roughtrax4x4.com or www.milneroffroad.com
      Cheers for the reply but it also vibrates when not moving.
        whats the engine mounts like.also the front diff mounts
        When its stationary and vibrating can you get underneath and check everything to see if anything is loose and check under the bonnet
          I have spent weeks under there nothing seems to be loose. You just can't see much under the bonnet as there is no room.
          When I rev the engine it rocks to the side but not excessive.
          When I am outside the vehicle I can't hear or feel the vibration, I can only feel and hear it inside. It is a loud strong vibration.
          If I have to brake sharply the vibration is severe when slowing and once I have stopped, when I put it in neutral it clears it.
            check the air filter box mounts as one of mine has broken and i get the same inside the truck as you say
            Another thing what is the idle tickover at on the rev counter
              I will check tommorow as off to work now.
              I think the idle speed is a bit low.
                I think the idle needs to be btween 750 and 850rpm so may may need to adjust that if it is low
                  Is the autobox fluid to the correct level and in good condition?
                    It is idling at about 650 to 700 rpm.
                    How do I increase the revs at tick over?
                    I think that I have found the cause of the vibration, it seems to be the exhaust vibrating against the bulk head. Atleast it doesn't seem to be something major.
                      Cheers for you reply.
                      The fluid id fine.
                      I think the cause of the vibration is the exhaust vabrating against the bulk head.So I will have to look at the rubber fixings.
                      Thanks again.
                        check the bolts securing your drivers seat
                          I think that I have cured it.
                          I adjusted one of the exhaust mounting brackets and put in a couple of plates and raised the gearbobox mounting bracket a couple of mm.
                          The engine idle speed is low I would appreciate it if you could tell me how to adjust it.
                          Thank you very much for your help you have been a great assistance.
                            its either adjust the tps or just adjust the throttle cable on the mechanism on the throttle body.Thiis is the way i would do it
                              The seat bolts are fine thanks
